Kona LH component out problem!!
Charlie
on Jun 15, 2007 at 3:56:10 am
Hi all, just was wondering if anybody has had a similar problem with their Kona LH...
system- FCP 5.1.4/OSX 10.4/4gb ram/MAC G5 dual-PCIx
problem- I am printing/mastering SD timline to Beta SP UVW 1800 via component and after making several successful beta masters I now have a scrambled component output that I can't correct. I've tried rebooting, shutting down, repairing permissions etc...I did try patching the FCP component directly to the monitor via component to make sure it wasn't my Beta deck.
Should I re-seat the card or is there something else I should do?
Much appreciated!
Charlie
JeremyG
Re: Kona LH component out problem!!
on Jun 15, 2007 at 4:01:20 am
Check your Kona control panel and make sure that you are in fact set to component and not composite + y/c. Reset your AJA easy setup.
Jeremy
Charlie
on Jun 15, 2007 at 11:57:22 am
Hi Jeremy, I did check my control panel last night and it is set to component. I am going to reseat the board this morning and I'll reset the easy setup.
Thanks! Charlie
Arniepix
on Jun 15, 2007 at 2:06:07 pm
While you're at it, check your cabling to make sure it hasn't come loose. If you have another component cable, swap it out.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
http://www.arniepix.com/blog
Charlie
Re: Kona LH component out problem!! SOLVED
on Jun 15, 2007 at 5:48:35 pm
Thanks for your help. Aja support emailed me today and suggested I trash preferences...I finally got around to it..working like a charm.
Thanks! Charlie
