Desktop Monitoring = poor playback on PAL broadcast monitor
ateale
on Jun 11, 2007 at 2:21:51 am
hey guys,
We are trying to play video out to our 2nd display (broadcast monitor) via the Default Kona Output "Macintosh Desktop", but the playback is quite poor.
If I drag a movie out to the 2nd display, using QuickTime Player, it looks like the video is playing at 18fps.
If I put the cursor out to the 2nd display and move it around the refresh rate is slow/low.
I thought it might be something to do with the Sys Prefs; Displays - currently the 2nd display is set to 1280x720 @ 60Hz.
I thought it would at least have to be at 50Hz - PAL? But 60Hz is all that can be selected.
If I play a clip out to the 2nd display using the Kona TV or VTR Exchange is play perfectly.
Is there some limitation to playback with desktop monitoring?
Cheers!
Adam
gary adcock
Re: Desktop Monitoring = poor playback on PAL broadcast monitor
on Jun 11, 2007 at 11:54:26 am
I am confused..
you say that it works great with Kona TV, but bad when you play out your desktop to a video monitor? of course, especially if you are trying to force interlace within a progressive display.
sounds like operator error to me.
[ateale] "We are trying to play video out to our 2nd display (broadcast monitor) via the Default Kona Output "Macintosh Desktop", but the playback is quite poor. "
that is to show the apple desktop on your secondary display or when you want to record content from your computer into a video device.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
ateale
on Jun 12, 2007 at 4:02:51 am
Hi Gary,
Thanks for getting back to me. I think u are right about it being operator error :)
"that is to show the apple desktop on your secondary display"
Yes that is what I meant - is it possible to get the Desktop to refresh smoothly?
Should the desktop monitoring be smooth?
Thanks again,
Adam
