AJA Kona TV & Targa Sequences
JeremyG
on May 30, 2007 at 7:46:14 pm
I just got a major load of tga sequence files from some 3d dudes. Is there a way I can play these sequences out through KonaTV? Do I have to render out a QT first? Will the DPX translator help me here or do I need to use QT?
I have never worked with image sequences before so I'm a little newbile here.
Jeremy
gary adcock
Re: AJA Kona TV & Targa Sequences
on May 30, 2007 at 8:15:23 pm
[JeremyG] "I just got a major load of tga sequence files from some 3d dudes. Is there a way I can play these sequences out through KonaTV? Do I have to render out a QT first? Will the DPX translator help me here or do I need to use QT"
I would use the Seq > Make movie setting in QTPro - But make a REF movie using the aja codec and it will playout via Kona TV. Just make sure that your stills are on a drive fast enough to play back the files in realtime ( about 300G a minute)
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
JeremyG
on May 30, 2007 at 8:29:21 pm
[gary adcock] "I would use the Seq > Make movie setting in QTPro"
Do you mean the Export > Movie to Quicktime function?
gary adcock
on May 31, 2007 at 1:02:51 am
[JeremyG] "Do you mean the Export > Movie to Quicktime function?"
In Quicktime PRO 7.1.6
from the File Menu
> Open Image Seg,
> set the desired frame rate
> then export a QT ref movie.
gary adcock
Studio37
David Roth Weiss
on May 30, 2007 at 10:25:29 pm
Jeremy,
Why are you not just importing them into FCP and playing on the timeline?
David
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles
JeremyG
on May 30, 2007 at 10:30:42 pm
They are a funky size at the moment, and I was just trying to get a sense of the movement. Qt has done the trick. I have to recomposite them @ 1920x1080 later.
Since QT can open image sequence, I figured Kona TV can.
Jeremy
David Roth Weiss
on May 31, 2007 at 1:49:27 am
So they don't have an alpha channel???
David Roth Weiss
Los Angeles
JeremyG
on May 31, 2007 at 1:54:38 am
Nope, no reason for them to have one. They are all 24bit.
