SDI to monitor SDI
johnpvp
SDI to monitor SDI
on May 30, 2007 at 2:24:25 am
At work I have FCP Studio 2 in a G5 2.66GHz Dual-Core Intel w/ 4GB memory I have the Kona LH card installed and a Sony HDV deck for capture. I connected the Kona to the SDI input on the monitor, but I'm only getting audio out of the monitor. I've visited the AJA site and read the pdfs they have, but I need more specifis regarding what connection goes where. The Kona has SDI in and 2 SDI out. I only went SDI 1 out to the monitor SDI in. Am I connecting correctly? Thanks!
uncompressed
Re: SDI to monitor SDI
on May 30, 2007 at 3:07:01 am
what does control panel say about your current connection?
gary adcock
on May 30, 2007 at 11:49:47 am
[johnpvp] " I connected the Kona to the SDI input on the monitor, but I'm only getting audio out of the monitor"
what monitor are you using, since not all support the SDI connections
my guess is that you do not have an SDI capable monitor.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
walter biscardi
on May 30, 2007 at 12:30:30 pm
[gary adcock] "
my guess is that you do not have an SDI capable monitor."
And along with that, also ensure you're using the latest 4.0 driver from AJA. That is a must for use with FCS 2.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Broadcast and independent productions.
All Things Apple Podcast! http://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! http://blogs.creativecow.net/WalterBiscardi
johnpvp
on May 30, 2007 at 1:12:08 pm
The monitor is the Panasonic BT-LH2600W P. I also downloaded the latest 4.0 software from AJA. Thanks for any help.
gary adcock
on May 30, 2007 at 3:16:31 pm
[johnpvp] "The monitor is the Panasonic BT-LH2600W P."
SO are you getting bars from the Kona card?
in the control panel, go to Controls and set it to test pattern > 75% bars
you should be able to see the bars on the monitor.
if not you need to call AJA tech support.
gary adcock
Studio37
johnpvp
on May 30, 2007 at 3:26:16 pm
Yes, getting bars...it must be a FCP Studio 2 setting I'm missing...
walter biscardi
on May 30, 2007 at 3:39:20 pm
[johnpvp] "Yes, getting bars...it must be a FCP Studio 2 setting I'm missing..."
Are you using an AJA Kona Easy Setup?
If so, ensure that External Video is set to All Frames.
