Kona Control Panel with FCS 2
Bullet
on May 26, 2007 at 2:06:55 pm
I have a dual 2.7 G5 with a Kona 2 and have installed FCS2 successfully. I also downloaded and installed the Kona 4.0 update.
The only problem I have found so far is that i am no longer able to open the Kona Control Panel to change output settings, etc. Anyone know what i need to do to get it working again?
Thanks in advance.
Brian McCartney
Re: Kona Control Panel with FCS 2
on May 26, 2007 at 7:05:46 pm
Same thing happend here. I was launching the AJA control panel from the dock but it wouldn't open. I guess the dock icon was pointing to the wrong control panel after the upgrade to 4.0. Just go into your applications folder and find the AJA Control Panel program there and open it. That should do the trick.
