AJA Kona driver version 4.0 for FCS2 released
AJA Sales Department
on May 19, 2007 at 1:50:45 pm
(May 18, 2007 at 4pm PST)
AJA is pleased to announce that the latest drivers for the Kona family of capture cards are now posted and available for download from the AJA website. These drivers are specifically designed for use with Apple's Final Cut Studio 2.
http://www.aja.com/html/support_swd.html
Of note:
Support has been added for Apple's Final Cut Studio 2 (KONA LS, KONA LH, KONA 3, and KONA 2)
Support has been added for Apple's Pro Res 422 and Pro Res 422 (HQ) codecs in Final Cut Studio 2 (KONA LS, KONA LH, KONA 3, and KONA 2) including Easy Setups
Once again, the 4.0 release is specifically designed to support Apple's Final Cut Studio 2. Users of previous versions of Final Cut Pro should refer to the Release Notes PDF file (included in the software download) for the appropriate driver version. The Release Notes PDF also contains other information on improvements, fixes and special notes.
Check the AJA website for an updated version 4.0 manual to be released soon.
AJA Driver Compatibility as of KONA Version 4.0 is as follows:
FCP 6.0.x (Final Cut Studio 2) - Kona Driver version 4.0
FCP 5.1.x - Kona Driver versions 3.1 through 3.4
FCP 5.0.x - Kona Driver version 3 (first Universal Binary version)
http://www.aja.com
AJA Video Systems
+1 (530) 274-2048 Intl.
(800) 251-4224 US
sales@aja.com
piper
Re: AJA Kona driver version 4.0 for FCS2 released
on May 19, 2007 at 6:04:41 pm
Kona 2 drivers are still at V3.4; are they coming later?
thanks,
Gary
SaltAire Cinema Productions
on May 19, 2007 at 8:35:42 pm
The Kona 2 version 4.0 driver was available with the rest of the updated Kona drivers. Perhaps your browser needs to refresh or is holding an old page in cache?
The URL for the Kona2 version 4.0 driver is:
http://www.aja.com/html/support_kona2_swd.html
Again, remember that version 4.0 is specifically for Final Cut Studio 2.
http://www.aja.com
AJA Video Systems
(800) 251-4224 US
sales@aja.com
piper
on May 19, 2007 at 9:53:18 pm
Ah, so it was. I just keep learning about this here computer.
Thanks to all of you at AJA for all you do.
OT: it was nice to see you again at NAB Brian.
Gary
Dave Jenkins
on May 20, 2007 at 4:42:46 pm
What about the IO Product line????
JeremyG
on May 20, 2007 at 10:32:18 pm
The io SD drivers come from Apple and so it is up to them to release the drivers, not AJA.
Jeremy
szumlins
on May 21, 2007 at 4:25:31 pm
AJA hasn't released easy setups yet for the Io and FCS2, but they will be available shortly. Apple provides the actual driver for the Io, so if you are lucky enough to have an Io and a copy of FCS2, you'll have to hand generate easy setups or just wait for a bit.
-Mike
Dave Jenkins
on May 23, 2007 at 4:59:39 am
Updated our AJA LA, all is working fine with the current drivers! Bonus, with FCP 6 you can play HD footage trough the LA to view on SD monitors. Down convert down by FCP 6.
