is it possible to capture HD 24P footage as SD 24P footage?
Justin
on May 3, 2007 at 1:13:43 pm
Hey all,
am I reaching for the stars in trying to achive the above?
I have a 24P HD tape and I want to capture it into my FCP system as SD at 24P.
IS there a way? I have tried playing around with the KONA settings but, at 24P there doesn't seem to be a way to downconvert 24P-HD to 24P-SD....
any ideas..suggestoins...hacks?
Timecode Multimedia
Re: is it possible to capture HD 24P footage as SD 24P footage?
on May 3, 2007 at 3:22:29 pm
If you are using a DVCPro HD or HDCam deck you can use the internal HD to SD output.
Most decks come with a SD - SDI output which has a live SD out at all times.
Then, you can use any of the SD 24P easy setups in FCP and capture through SDI.
If you are using an HDV deck then you should use the component HD out, but switch the
deck's own menu to do the downconversion (most of them have that feature) and capture via
component.
Hope it helps...
Stuart Ferreyra
Timecode Multimedia
President
Santa Monica, CA 90025
http://www.timecodemultimedia.com
gary adcock
on May 3, 2007 at 4:32:58 pm
[Justin] "IS there a way? I have tried playing around with the KONA settings but, at 24P there doesn't seem to be a way to downconvert 24P-HD to 24P-SD...."
TYPE OF HD 24p?
with HDCam or Varicam - this is a preference in the kona capture settings if your working in driver v3 or later.
with HDV that is a very different question.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
