2K Workflow
Sven
2K Workflow
by
on Apr 30, 2007 at 5:59:39 pm
Hi there,
I've a question regarding to the 2K capabilities of the Kona 3.
What we need for the next project is a workstation that can handles 2K DPX Files in the 1:1,85 format.
From the filmscanning process we will get the full 35mm frame in 2048x1556 pixels in bit lin or log.
On the output sided we need the 1:1,85 aspect ratio which means 2048x1107pixel @ 24fps.
In the specifications I read:
2048 x 1556psf 23.98
2048 x 1080p 24
So my question are:
1. Is it not possible to playback 2048 x 1556 @ 24fps?
2. Are there no possibilities for aspect ratios other than 2048 x 1556 and 2048x1080 ?
Thanks in advance.
Sven
gary adcock
Re: 2K Workflow
on May 2, 2007 at 6:27:29 pm
Sven
Aja has a white paper on their website with a good overview
http://www.aja.com/html/support_kona3_doc.html
[Sven] "Is it not possible to playback 2048 x 1556 @ 24fps?"
Yes it can, however most modern post workflow is based on 23.98 so that you have a realtime conversions to video and correct sync for audio.
"Are there no possibilities for aspect ratios other than 2048 x 1556 and 2048x1080 ?"
those are the acquisition frame sizes, there are a couple of great tips for various output formats by using the DS keyer function in the Kona Control panel and by using a Mask file created in photoshop you can output various frames to tape.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
