Downconvert Edit to tape
Eli Mavros
on Apr 18, 2007 at 3:39:29 pm
How do I take a DVCPRO HD 720p24 and lay it off to digibeta. I tried using the 525 NTSC 10bit easy setup and then just dragging the HD sequence into the edit to tape window, but it did not work. What is the right process for doing this. I know that I've done it before, but having a brain fart. I am using a Kona LH.
Eli Mavros
JeremyG
Re: Downconvert Edit to tape
on Apr 18, 2007 at 5:04:32 pm
Hopefully this will help:
http://forums.creativecow.net/readpost/8/929482?
Jeremy
Eli Mavros
on Apr 18, 2007 at 7:12:05 pm
Thanks a bunch, will give it a whirl.
Best,
Eli
