Kona 2 or Kona LH
jjbriquet
Kona 2 or Kona LH
on Apr 12, 2007 at 9:55:11 pm
Hi I have a Dual G5 1.8 and I can get either a Kona 2 or Kona LH for about the same price, which one should I get and why.
Basically I will be using it for HDV editing in DVCProHD format, some SD uncompressed projects from time to time (I really need to be able to output only 1 stream of SD 10bit uncompressed)
Also, can I capture HDV via RGB analog into LH to DVCProHD?? This way I wold not need a converter for the time being.
Lots of questions so thank you in advance for any advices,
JJ
Bob Zelin
Re: Kona 2 or Kona LH
on Apr 13, 2007 at 1:35:47 am
the LH will allow you to bring in the analog HD right into the board - the Kona 2 will require a converter. The LH is the right choice for you, at this time.
Bob Zelin
jjbriquet
on Apr 13, 2007 at 3:34:30 am
Sounds Great, thanks for the info. I will go with the LH then - JJ
David Roth Weiss
on Apr 13, 2007 at 1:37:18 am
The LH has balanced analog audio I/O. I think you'd be quite happy with it.
