NTSC To PAL
boomdown
NTSC To PAL
on Apr 11, 2007 at 6:01:41 pm
Is it possible to take HDV material on tape and capture it to DVCPROHD 50i? Then reoutputting the DVCPROHD 50i to PAL tape. Essentially doing a NTSC to PAL conversion.
If not, how would I go about doing a conversion from HDV NTSC to HD PAL tape.
Thanks in advance
weevie833
Re: NTSC To PAL
on Apr 12, 2007 at 6:34:59 pm
The card won't do a standards conversion, neither in nor out. But you can use the Nattress Standards converter plugin:
http://www.nattress.com/Products/standardsconversion/standardsconversion.ht...
I don't know if works in downconversion. In other words, you may need to downconvert to SD first, then standard convert. It ain't an Alchemist, but it's not bad.
steve covello
double wide post
