Up res HDV
Sean Davison
Up res HDV
on Mar 20, 2007 at 11:11:07 am
Im trying to Digitise some HDV footage and up res it to DVC Pro HD through the component inputs on the Breakout Box
Ive got the HDV deck set to output Component and the right leads plugged in to the inputs on the box. Ive set the Kona control panel to input analog video (component Beta SP) and created a new capture setting using the 625 setting as my input and DVC ProHD as the conmpressor
Cant get it to work!!!
Any clues?
walter biscardi
Re: Up res HDV
on Mar 20, 2007 at 12:16:05 pm
[Sean Davison] "Ive set the Kona control panel to input analog video (component Beta SP) and created a new capture setting using the 625 setting as my input and DVC ProHD as the conmpressor"
What? Where does BetaSP and 625 come in?
What is your HDV footage? 1080i/50 or /60?
Set to the AJA Kona DVCPro HD 1080i/50 or 60 and then change the Device Control to Firewire NTSC to control the deck.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
Sean Davison
Re: Up res HDV
on Mar 20, 2007 at 1:26:32 pm
sorry not hdv - dv! need to get it into a dvcprohd timeline using component out
JeremyG
Re: Up res HDV
on Mar 20, 2007 at 2:32:25 pm
You should choose the proper DVCPRO HD easy setup and the Kona will upconvert the DV footage for you.
Jeremy
JeremyG
Re: Up res HDV
on Mar 20, 2007 at 2:33:06 pm
I should add that as long as the frame rates are compatible.
Sean Davison
Re: Up res HDV
on Mar 20, 2007 at 3:15:12 pm
I cant get the BO box to upconvert the Component signal
walter biscardi
Re: Up res HDV
on Mar 20, 2007 at 3:17:18 pm
There are instructions for this in the manual, but set your Primary to match the DV deck and the Secondary to match whatever your HD upconvert is to be in the Kona control panel.
Then switch back to FCP and the control panel should now show the SD signal being upconverted.
David Smith
Re: Up res HDV
on Mar 20, 2007 at 9:38:40 pm
[Sean Davison] "Im trying to Digitise some HDV footage and up res it to DVC Pro HD through the component inputs on the Breakout Box"
[Sean Davison] "I cant get the BO box to upconvert the Component signal"
Correct me if I'm off base here guys, but since Sean says he's trying to get footage into the computer via component analog, that would point to a Kona LH/LHe board. That board does not upconvert, does it?
Regards,
David
walter biscardi
Re: Up res HDV
on Mar 20, 2007 at 9:44:05 pm
[David Smith] "Correct me if I'm off base here guys, but since Sean says he's trying to get footage into the computer via component analog, that would point to a Kona LH/LHe board. That board does not upconvert, does it?"
D'OH! You're absolutely correct. The LH / LHe models DOWNconvert only, no upconvert. I need more coffee!
JeremyG
Re: Up res HDV
on Mar 20, 2007 at 9:46:57 pm
Uhhhhh, yeah. Geez, thanks for the reminder David.
I need more smart pills, coffee be damned. :-)
Sean Davison
Re: Up res HDV
on Mar 21, 2007 at 9:11:41 am
I need another Kona card!!! We found that out at 1am!!!!! Thanks chaps - my mistake
