Kona 3 in slot 4?
Per W. R
Kona 3 in slot 4?
on Mar 15, 2007 at 11:14:33 pm
Hi!
I have bought a MacPro with a Kona 3 card installed in slot 4. The installation notes delivered with the card says it should be in slot 3 for optimal performance.
As far as I can see, I have no problem with the card. What could happened? Should I move it to slot 3?
/Per
walter biscardi
Re: Kona 3 in slot 4?
on Mar 16, 2007 at 1:16:46 am
If AJA says Slot 3 is optimal, you should install it into Slot 3. Those folks spend a LOT of time testing all this stuff for us and I always follow their instructions to a T. Including the Expansion Slot utility.
Walter Biscardi, Jr.
http://www.biscardicreative.com
HD Editorial & Animation for Food Network's "Good Eats"
HD Editorial for "Assignment Earth"
"I reject your reality and substitute my own!" - Adam Savage, Mythbusters
Bob Zelin
on Mar 16, 2007 at 1:51:35 am
the slots in the Mac Pro are dynamic, and the number of lanes can be changed with the apple Expansion Slot Utility. Slot 3 is the "safe" slot, as you can't screw it up (by making it a 1 lane slot). Everything depends on where you put your storage host card (SATA, Fibre, or SCSI).
Bob Zelin
Per W. R
on Mar 16, 2007 at 7:09:51 am
I'm just running Firewire 800 drives right now. Mayby I should move the card anyway.
Per
