FCP settings for digi beta deck
jenelle
on Mar 15, 2007 at 4:28:12 am
does anyone know the correct easy setup for a sony digi beta deck? I have deck control, timecode & audio but I can't see the video & it won't capture
John Davidson (fomerly JNeo25)
Re: FCP settings for digi beta deck
on Mar 15, 2007 at 7:56:08 pm
I use the Kona 8Bit Uncompressed with a Kona 2 - sometimes I use 10-bit.
Make sure your deck has SDI selected as input.
What I/O card do you have? Which deck are you using?
JD
Scott Shucher
on Mar 15, 2007 at 7:58:44 pm
Check you Kona control panel, and make sure you select the correct SDI input.
The correct capture setting, assuming NTSC is AJA Kona 525 - 29.97 10 bit. (or 8 bit for smaller file sizes
and a little less quality. For PAL you should use 625-25 10bit.
How are you getting audio. Embedded, AES or analog?
