AutoCAD 2011 Error
COW Forums : Color Grading
Otto Cech
AutoCAD 2011 Error
on Aug 22, 2016 at 4:05:23 pm
Help to restore information. from file the most part of information was gone. the preview shows how it looked before error.
AutoCAD 2011 gives out either a fatal error either internal. how to fix it?
Otto Cech
Re: AutoCAD 2011 Error
on Aug 24, 2016 at 5:50:53 pm
what do I do? any ideas? I would be grateful for any advice.
rian oryan
on Aug 25, 2016 at 5:49:19 pm
To try to open a backup copy of the file (bak, sv$), having replaced the .bak expansion or .sv$ for .dwg.
The default directory for storage of temporary files can be defined by calling the settings window
_.options, Files tab, the branch Temporary Drawing File Location.
Either through the dwg file recovery tool like DWG Recovery Toolbox you can quickly restore your .DWG file . Here the link https://www.oemailrecovery.com/dwg_recovery.html
Otto Cech
on Aug 29, 2016 at 1:31:01 pm
Thank you for the help!
rian oryan
on Sep 4, 2016 at 1:44:18 pm
Have you tried dwg recovery tool as I advised?
