is it possible to use or convert an icc profile of a monitor to a look to be applied to a movie ?
COW Forums : Color Grading
Jacques Davis
on Nov 24, 2018 at 7:38:04 pm
Hello,
I color grade HDTV movie on a calibrated monitor.
I play the movie with an android player on the same monitor.
Problem is android has no color management.
So is there a way to use the profile of the monitor to create some kind of look (or lut) that
could be applied to the movie.
Your science is welcome
jd
Chris Wright
Re: is it possible to use or convert an icc profile of a monitor to a look to be applied to a movie ?
on Nov 24, 2018 at 11:09:04 pm
there's many ways to convert icc to lut. but you need to figure out what the transformation is. software needs a input icc and output icc to determine what colors to shift. you can do all this in AE, photoshop, spaceman, etc.
