Color Finale LUT Gallery
COW Forums : Color Grading
Kyle Remmenga
on Mar 29, 2017 at 12:04:18 am
I was all excited to play with the LUT Gallery in Color Finale Pro, but the check box is not available. Did they rearrange the way to access it in an update or simply do away with it? I have been searching high and low and can not find it...
Color Finale Pro 1.6.1
Google is mostly bringing up highlights to this feature and no word of why I may be missing it... Grrrr....
Anybody else having this issue?
(Fix: I just reinstalled it and it works fine now. Don't know why it wasn't loading before. When I did the migration of LUTs I made sure remove originals was unchecked, but I'm fairly certain I did that before. However, I may be mistaken. But if you run into this issue as well, best I can say for now is to be sure you don't check remove originals hen installing. It may also have just needed a reinstall.)
