Sony Catalyst Browse : COPY with Use mark in/out points (checkbox not selectable) ?
COW Forums : Sony Catalyst
VIEW ALL   •   PRINT
Alain Van Haecke
on Mar 2, 2016 at 5:03:34 am
hi,
I would like to COPY with Use mark in/out points but the checkbox is grayed out, no way to check it ON (in Sony Catalyst Browse).
Is there a way to copy a part of a clip and not the entire clip itself ?
Of course, I added in/out points in the clip before trying to copy it.
When I transcode, it works with in/out marks but not when I copy.
Shots are from my xdcam-ex1r mp4 35Mbps.
I prefer to Copy and not Transcode because I preserve the BPAV folder and it is faster (like in Sony Content Browser but it freezes/crashes all the time so it became unusable). Hope you understand my stress.
my second question is:
if I transcode (not copy) into the same Format (XDCAM) and same Preset as shot (MPEG HD 1920x1080-25p 35 Mbps) without adding any lut (No color adjustments) and Output Rec.709, is there some loose of quality/compression ? I don't really see by eyes but I would like to ask you,
VIEW ALL   •   PRINT
