Catalyst Browse will not combine relay clips
COW Forums : Sony Catalyst
<< PREVIOUS   •   VIEW ALL   •   PRINT
Liz Parham
on Apr 11, 2018 at 6:56:39 pm
When I import the two clips with sequential timecode, shot with the same camera, I place both in the same folder and I attempt to use the combine tool, I keep getting an error message "Unable to merge selected relay clips. The clips use different media formats or the timecode of the clips is not sequential."
I'm wondering if it's because the end timecode of the first clip (23 sec 4 frames) is the same as the starting timecode of the second clip...as in the second clip should start at 23 sec 5 frames instead of 4.
