Luts for Sony Vegas Pro 13 for slog2 and slog3
COW Forums : Sony Catalyst
VIEW ALL   •   PRINT
Terry Hogan
on Jul 13, 2016 at 1:04:43 am
I found that Catalyst Browse lets you convert your slog2 or slog3 4K video file from a camera like the Sony a7Sii to rec 709 and gives you tools to further adjust color (curve, color wheels, scopes, etc) and then lets you save (export) all your adjustments as a lut cube file. Then you can use the Color Vision free plugin for Sony Vegas Pro 13 to apply the same Catalyst Browse color adjustments to the same original files now on the Vegas Pro 13 timeline where you could further adjust color if needed with Vegas Pro's tools. I was finding it tough adjust color of slog2 and slog3 video clips in Vegas Pro prior to learning how easy it is to work with those files in Catalyst Browse. http://www.sonycreativesoftware.com/catalystbrowse http://www.vision-color.com/lutplugin/
VIEW ALL   •   PRINT
