How to Resize image in BlackMagic Fusion 8
COW Forums : Blackmagic Design Fusion
mattie trevor
on Dec 29, 2016 at 11:01:41 am
im just started Fusion by my compositing knowledge from ae.the node based is little headspin. but my current problem is the mask i created in an image that scaled by transform node, the scaled postion of the image chnages after i connect the shapemask node to the image.
Image Attached
https://f1.creativecow.net/file/10909/10909_capture.png.zip
Simon Ubsdell
Re: How to Resize image in BlackMagic Fusion 8
on Dec 29, 2016 at 11:27:39 am
The scale of your comp (i.e frame size) at any one time is determined by the background image. In that sense Fusion is completely unlike Ae.
Without seeing more of your flow I can't say what's gone wrong here, but that is the answer to your question.
Maybe post your composition here so we can advise more specifically?
Simon Ubsdell
tokyo productions
hawaiki
mattie trevor
on Dec 29, 2016 at 2:35:47 pm
Thanks for the replay sir. but i think u didnit seen my attached image (link of the image i uploaded ) if u want to see my workflow for more details about my problem.
Simon Ubsdell
on Dec 29, 2016 at 2:49:18 pm
Yes, I saw the framegrab, thanks.
Without knowing the frame sizes of your background and your foreground images and your desired output image I can't be more precise.
From what I can see your background image is 1024x520, is that right?
What is the frame size of your foreground image?
What is the frame size or your final output?
Thanks.
Simon Ubsdell
tokyo productions
hawaiki
Simon Ubsdell
on Dec 29, 2016 at 2:54:49 pm
Oh, and what are you doing with your transform?
You will find it a lot less confusing if you use the transform options on the Merge node.
Simon Ubsdell
tokyo productions
hawaiki
Simon Ubsdell
on Dec 29, 2016 at 8:28:09 pm
I notice that I have already answered this question at some length on this forum:
https://forums.creativecow.net/readpost/391/79
Hope that helps.
But please let me know if you need any further guidance.
Simon Ubsdell
tokyo productions
hawaiki
