Fusion 8 Mac not loading QuickTime RGB Alpha, PNG codec
COW Forums : Blackmagic Design Fusion
Fabio Cormack
on Apr 13, 2016 at 10:57:29 am
Hi There
a quick help would be much appreciate please:
Fusion 8, Mac, El capitan, not loading files on this format: QuickTime RGB + Alpha, Video Codec: PNG
Do I need to convert these files? If yes for what format in order to preserve alpha? Compressor would work for conversion?
Thank you so much!!!
Fabio Cormack
Davinci 8 - Tangent Wave - Decklink HD Extreme 3D+
Final Cut Suite
Adobe CS5.5 Suite
Rio de Janeiro - Brazil
Simon Ubsdell
Re: Fusion 8 Mac not loading QuickTime RGB Alpha, PNG codec
on Apr 13, 2016 at 11:24:50 am
PNG compression is not supported to QT movies. Here's the list of compression types that are supported:
Simon Ubsdell
tokyo-uk.com
Fabio Cormack
on Apr 13, 2016 at 11:28:33 am
Thank you so much Simon!
Converting the files to QT ProRes + Alpha is working - I'm using Apple Compressor - is there any other way to go to not loose quality?
Fabio Cormack
Final Cut Suite
Adobe CS5.5 Suite
Simon Ubsdell
on Apr 13, 2016 at 11:35:22 am
Go for one of the Uncompressed options if quality is very, very important - otherwise, I would opt for ProRes 4444 which should be plenty good enough for most purposes and will be easier to work with. Conversion through Compressor should be fine.
Simon Ubsdell
tokyo-uk.com
Fabio Cormack
on Apr 13, 2016 at 11:38:14 am
Once again, thank you so much
I think ProRes 444will work fine :-)
Have a great day!
Fabio Cormack
Final Cut Pro X
Fusion 8 - Adobe CC Suite
