Combine 4 EXR files into a single Multichannel EXR
COW Forums : Blackmagic Design Fusion
Justin Imhoff
on Dec 15, 2018 at 4:44:56 pm
I'm trying to combine several Cryptomatte EXR files from V-Ray into a single, Multi-channel EXR file using Fusion9. I read somewhere you can do this the a channel boolean node but I have no idea how. Is anyone able to assist?
Many thanks.
JJ
Simon Ubsdell
Re: Combine 4 EXR files into a single Multichannel EXR
on Dec 16, 2018 at 11:11:26 am
You need to go to the Aux Channels tab of the Channel Booleans tool and use the dropdown menus to select which foreground input to add to which background channel:
Note that this tool only takes two input so you will need three instances if you are combining four inputs.
Simon Ubsdell
tokyo productions
hawaiki
Justin Imhoff
on Dec 16, 2018 at 3:20:43 pm
Thanks for the reply. I'm not sure which foreground input to put into which channel. I tried this way but it didn't work.
