Fusion Proxy?
COW Forums : Blackmagic Design Fusion
Murat Egretli
Fusion Proxy?
on Apr 29, 2018 at 8:00:53 am
Hi there,
If you use DaVinci Resolve, you'll probably know "Generate Optimized Media" option. To edit Ultra HD videos fluently, it resizes the video and creates a cache for it. I don't know if fusion has a similar feature or not. I need some info. Thanks.
Marco Feil
Re: Fusion Proxy?
on Apr 30, 2018 at 8:39:10 am
Theres a PRX button on the lower right under the timeline. Right click it to choose which proxy level you want - it then only calculates one out of every x pixels.
You can also specify a proxy file in each loader node which will be used when you press the PRX button.
Murat Egretli
Re: Fusion Proxy?
on Apr 30, 2018 at 7:47:59 pm
Thank you :)
