Sherlock balance effect
COW Forums : Blackmagic Design Fusion
Leonhard Wolf
on Jul 8, 2017 at 11:47:51 am
Hi everyone,
I recently watched Sherlock season 4 and noticed this cool effect: Sherlock throws a bag and guesses the weight in slow motion. To show this there is a text animated to go from 1 to 1000 and back down again.
I was wondering how you could achieve that in Fusion. Sadly I can't seem to figure out how to animate the text itself. Would you have to use expressions or Python?
I would be happy for suggestions to pull this effect off!
Mainboard: Asus Maximus Ranger VII
CPU: Intel i7-4790k (not overclocked)
GPU: AMD Radeon HD 6870
RAM: 8GB
Soundcard: Avid Eleven Rack
HDD: 2TB
OS: Windows 10 Home, 64bit
Simon Ubsdell
Re: Sherlock balance effect
on Jul 26, 2017 at 10:56:16 am
In the Text tool, right-click on the Styled Text box, select Expression and enter the following expression:
Text(iif(time<50, max(1, time*20), max(1, 2000-time*20)))
This will count up from 1-1000 over 50 frames and then down from 1000-1 over the next 50 frames.
There are many different ways of doing this depending on what you want to achieve.
You could control it in a different way by simply adding an expression that links the Text to an animated parameter on another tool. So for example, you could animate the Size of a Transform tool (it doesn't even need to be connected to anything) from 1-1000 and then instead of the above expression in the Styled text field you could use the following:
Text(Xf.Size)
(To make that work rename your Transform tool to "Xf".)
Simon Ubsdell
tokyo productions
hawaiki
Leonhard Wolf
on Jul 28, 2017 at 10:47:03 am
Thanks for your suggestion.
It worked for me!
RAM: 8GB
HDD: 2TB
