Inserting footage into an animated phone object
COW Forums : Maxon Cineware
Ellouise Houbert
on Sep 20, 2017 at 12:03:46 am
Hi guys,
I need to animate a phone and then add animated UI footage into the screen in the phone. Is there a way to do this in after effects to get the timings right? (ie: animate the object in cinema 4d and somehow track the footage onto the screen of the phone in after effects?) Or am I better off adding the footage to the phone screen as a texture?
Ellouise.
Angie Taylor
Re: Inserting footage into an animated phone object
on Jun 17, 2018 at 6:41:41 am
You can animate the Phone in C4D. Import the C4D file into AE, drop it into a new comp. This will apply the Cineware effect to the layer. In here, chose to EXTRACT the data from C4D. This will import the same camera used in C4D so you can now create your UI in AE. As long as the UI is 3D in AE it should line up with your C4D animation :-)
cheers,
Angie Taylor | Creative Cabin Ltd | Linkedin Instructor | Adobe Community Professional
http://www.creativecabin.co.uk
https://www.lynda.com/Angie-Taylor/2131450-1.html
Twitter: theangietaylor
Linkedin: theangietaylor
http://www.facebook.com/pages/Angie-Taylor/118378194869002
