Removing grid plane in composition
COW Forums : Maxon Cineware
Christopher Gomersall
on Jan 20, 2017 at 7:34:02 pm
I do NOT want to see the ground plane grid in my final render to AE. How do I get rid of it?
Kind regards,
Chris Gomersall
http://www.vimeo.com/channels/texasvideopro
http://www.youtube.com/upstairsmedia
Steve Bentley
Re: Removing grid plane in composition
on Aug 2, 2018 at 1:40:05 am
When you say ground plane - do you mean the grid? or a plane primitive you have in your scene. If the latter you can either check the bottom visibility "stop light" on the ground object or add a compositing tag to the ground object and set the Scene by Camera to off in the tag.
For the former, the grid should not be rendering. What render engine are you using? Are you using the cell shader or sketch and toon?
