Problem Extruding AI Text
COW Forums : Maxon Cineware
Neal Sickles
on Jul 8, 2016 at 11:05:34 pm
Hi, I'm sure this has been discussed here, but I have not found a thread with a viable solution. I'm using Cineware with After Effects and I've created some text that I prepped in .ai8 by converting it to outlines. When I bring into Cineware with the Merge Objects command and apply extrude to a letter, the holes in the letter do not get punched out. I've read other forums where they talk about the C4d plugin, but it seems to require the full version. I've also tried deleting the path of the hole in AI, but it doesn't do anything. Has anyone found a solution for this for Lite users?
Thank you,
Neal
