Multi pass isn't rendering correctly
COW Forums : Maxon Cineware
brad nall
on Apr 13, 2015 at 12:20:05 am
Tracked w/ AE's camera tracker and created a new C4D file.
inserted text and created multiple passes.
A. Object buffer for the 3d text
B. Shadows pass
C. Ambient Occlusion pass
Layered all in AE correctly with tack mattes and blending modes.
This is where it gets weird....
Sometimes it renders a completely black frame...
Sometimes it looks like the Multiply mode is inverted and the part of the image that should be a shadow is visible, the rest is black.
this link is just a render of a few frames of the AE COMP.
None of the settings change from the clean frame to the dark frame.
To me it looks like the line between C4d and AE just ?breaks?
Anyone else ever seen this type of issue?
Lasse Koivisto
Re: Multi pass isn't rendering correctly
on Apr 24, 2015 at 10:01:02 am
Hello. I have the same problem. Did a 3d text in C4D lite, then use cineware in after effects to import it to tracked footage. Multipass things such as Shadows, AO and object buffer. Some frames work, anothers don't... Tried few times different settings... It dont work. Watched some tutorials, but not working. (sorry for bad english)
