I have a wonky folder, a saved AVCHD card, that won't copy and gives me Error Code -36 when I try
COW Forums : Storage
Noam Osband
on Aug 2, 2016 at 7:24:00 pm
I copied an AVCHD card to my backup hard drive. I renamed the folder. I am trying to backup the card but it doesn't complete the operation. i get the error message "The Finder can’t complete the operation because some data in “BDMV” can’t be read or written. (Error code -36)." I tried duplicating the folder and I got the same error message.
I opened the folder in FCP X to import the files, and it takes a while to open (hello spinning wheel!) but it eventually does and I could potentially import that way.
Any idea how I can backup the folder? I can't think of any fix.
Chris Sebes
Re: I have a wonky folder, a saved AVCHD card, that won't copy and gives me Error Code -36 when I try
on Oct 14, 2016 at 4:27:04 pm
Do you have another computer available? If so, try and network to the problem drive/computer and copy the file locally to the second computer. If you can use a Windows machine, this may ignore the error that the Mac is throwing up. At least this way you can try and make a backup of the file. Then make another copy elsewhere and see if that clears things up. Good luck!
Chris Sebes
Senior Video Editor
http://www.MediaMIxStudios.com
