Can I use a Lacie AC adapter with a G Drive?
COW Forums : Storage
Ned Miller
on Jan 18, 2016 at 9:27:59 pm
I have many Lacie AC adapters for the silver vertical hard drives and can't find my G drive adapter, a silver vertical full size unit.
Is it safe to use the Lacie adapter? If someone has a full size, horizontal silver G drive could you please send me the voltage data on it's AC adapter?
Ned
Ned Miller
Chicago Videographer
http://www.nedmiller.com
www,bizvideo.com
Bob Zelin
Re: Can I use a Lacie AC adapter with a G Drive?
on Jan 20, 2016 at 5:53:29 pm
I went to google -
the Lacie power supplies are 12 V power supply
and look, here is the result of the google search on the
G-Technology power supply -
http://support.g-technology.com/kbase/users/kb.php?id=161&print=1
so it's 12 V also !
so yes, it should work.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com
Ned Miller
on Jan 20, 2016 at 6:51:10 pm
Thanks Bob. So the current doesn't matter? I thought it was an inner pin thing and that could blow the supply. So you're saying any of my Lacie 12v can do it, right?
Ned
Ned Miller
www,bizvideo.com
Bob Zelin
on Jan 20, 2016 at 9:18:06 pm
the power supply has a current rating. This means that the drive requires a certain amount of amps to operate. For example, you keep plugging in lamps, and a vacume cleaner into your wall outlet of 15 amps. After a certain point, the circuit breaker will blow, because it does not have enough amperage to power all the lamps, vacume cleaner (and air conditioner).
Same with this - the drives take 12 V. I assume that the power supplies (you did not specify exact models) take 1.5 - 2 amps.
If you have a G-Tech that takes 3 or 4 amps (I doubt it), then the power supply will get very hot to the touch, and eventually stop working. But I am guessing that these are all 1.5 to 2 amps, so you should have no issue.
And when smoke starts to bellow out of your drive array, well, I really make sandwiches for a living and just stalk on Creative Cow.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com
