G-Raid/Data Rescue - Bad recovery files
COW Forums : Storage
Kim Bo
on Jan 6, 2015 at 6:01:02 pm
I've got an G-Raid 8TB external hard drive. I had problem with the drive, it was always ejecting by itself... So I needed to back up all my videos files, and I used Data Rescue 4 to recovery all the files since my external hard drive was always ejecting by itself and I was not able to use it anymore.
Once I did all the back up of my files, I format my external drive.
But, now, from the flies that I recovered, I've got video files that are fragment, that are very bad. So I call for some support to Data Rescue, and they told me to do a deep scan. But my external hard drive always eject by itself, so I'm not able to complete my deep scan.
Anyone could help, what should I try or do...
Gene Gilbert
Re: G-Raid/Data Rescue - Bad recovery files
on Jan 7, 2015 at 8:46:24 pm
Hi Kim,
Thanks for your post. Which G-RAID model do you have, is it the USB 3.0 version? If so, the disconnecting issue you are seeing may possibly be addressed with a firmware update. Here is a link to the firmware updates: http://support.g-technology.com/support/firmware-updates
You may also contact me directly at eugene.gilbert@hgst.com for further assistance. Please let me know if you have any questions.
Regards,
Gene Gilbert
g-technology.com
Kim Bo
on Jan 7, 2015 at 8:52:13 pm
This is the model I got: G-Technology 8TB G-RAID External Dual-Drive Storage System
The link of the firmware update you send me it's for G-Drive. Is it the same I need to use?
I will try to do the update! Hope it will work
Gene Gilbert
on Jan 7, 2015 at 9:00:48 pm
Hi Kim,
There is a G-RAID update on there as well, I believe it is the 4th one down, says G-RAID v5. If your G-RAID has one USB 3 port and 2 Firewire 800 ports, then this update would be for that model.
Regards,
Gene Gilbert
g-technology.com
Kim Bo
on Jan 7, 2015 at 9:26:22 pm
It doesn't work... I did the update, then I run Data Rescue to try to recovery my files... but the hard drive still eject by itself. I install G-Raid v5 like you suggest me. And yes my hard drive have one USB 3 port and 2 Firewire 800 ports.
Gene Gilbert
on Jan 7, 2015 at 11:32:18 pm
Did you cycle the power by turning the drive off and back on? That is necessary for the update to work.
Regards,
Gene Gilbert
g-technology.com
Kim Bo
on Jan 8, 2015 at 12:07:16 am
Yes I did... and it's really said that I've got the lastest update
Gene Gilbert
on Jan 9, 2015 at 4:59:31 pm
Have you tried using the USB port? If it also does it on the USB port it most likely is an issue with one of the drives in the unit. I would recommend a data recovery company and replacement of your drive.
Regards,
Gene Gilbert
g-technology.com
