Can 2 x Lacie 4big Quadra 12TB be Combined into 1 larger Raid System
COW Forums : Storage
Opie Sayner-Hassall
on Aug 1, 2013 at 3:59:07 am
I have just purchased a 2nd Lacie 12TB 4big Quadra external storage drive.
Is it possible to combine both drives into 1 bigger storage raid system?
Regards,
Opie
Alex Gerulaitis
Re: Can 2 x Lacie 4big Quadra 12TB be Combined into 1 larger Raid System
on Aug 1, 2013 at 6:33:20 am
Yes, with spanning or striping in either OSX or Windows. What system (hardware, OS) are you using?
Opie Sayner-Hassall
on Aug 2, 2013 at 2:52:19 am
Mac Pro, Quad-Core Intel Xeon - 2.8GHz
Mac OS X 10.7.5
Do you know of any tutorials or blogs that I can learn how spanning and stripping process?
Thanks for verifying that it can be done.
Opie
Alex Gerulaitis
on Aug 2, 2013 at 11:53:51 pm
I thought I replied but maybe my post is still sitting in the moderation queue...
First, a correction: RAIDing removable / portable drives is neither recommended nor supported, so you may not be able to RAID two of your Quadras together. I completely blanked out on this when responding. In general, the device must appear to the system as "fixed" in order to be a part of a RAID set.
Here is one relevant article:
https://support.apple.com/kb/PH5834
