Picking new Raid Drives
COW Forums : Storage
Bob Miller
on May 6, 2017 at 7:07:57 pm
Hello,
So, I'm editing off a Macbook Pro 15 inch 2014 maxed out on Premiere Pro (I know, it's not a beast for editing) and recently got a gig where I was given a regular bus powered drive with 4K compressed footage (from Canon). Anyways, I had problems with it and realized I should have transferred that bus drive footage onto my USB 3.0 Raid from OWC. (The difference being 99 read/write to 206 read/write)
This of course sent me down a rabbit hole that maybe I need a bigger faster drive in general. So, I started looking at some numbers.
My SSD drive on my computer has these numbers:
I was curious what speed was fast enough for a 2160p25/30 timeline across the board (see circled section).
In other words, if 900 write/read is getting me to knock out some of the 2160p50/60 numbers, what's the minimum I need to just get where I circled.
Was looking at these options. All of which unfortunately posted their disk speed in a different format and don't list 2160p25/30:
https://eshop.macsales.com/item/OWC/TB2IVT08.0S/
677.5 write / 703.7 read
https://eshop.macsales.com/item/OWC/TB2IVT12.0S/
736.1 write / 743.8 read
This is obviously not fast enough, but put here for the heck of it because it's cheaper:
https://eshop.macsales.com/item/OWC/TB2U3MED04TH/
which is around 380 write /read
I also understand in my current setup that at a certain point the bottle neck becomes not the disk speed but the actual power/graphics card of the system. And perhaps I'm better served just getting the cheapest/slowest option I posted below and working with proxies. I suppose I was thinking I'd get a disk drive system that could be upgraded when I upgrade to a PC tower of if Apple ever releases something!
Thanks in advance,
Bob Zelin
Re: Picking new Raid Drives
on May 7, 2017 at 5:04:04 pm
the more drives you have spinning (either SSD or SATA) the faster the array will run. 4 drives run faster than 2, 6 drives faster than 4, 8 drives faster than 6. Buy a RAID - end of story. These products are not expensive. Don't think about "what happens when I get a new PC or Mac Pro in 2019" - your gear will be obsolete by then - your 2014 MacBook Pro will seem silly in 2019. Everything becomes obsolete quickly these days. Buy what you need to make a living, and bill your clients. Don't worry about your long term investment (one exception - buy a comfortable chair for yourself - that will still be good in 2019).
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com
greg janza
on May 9, 2017 at 7:19:15 pm
[Bob Miller] "This is obviously not fast enough, but put here for the heck of it because it's cheaper:"
For 4k editing with compressed files, that speed is more than enough. If you plan on editing uncompressed 4k you're going to need a beefy raid at max speed but for compressed 4k, a raid that tests around 400/MB/s read/write will be quite sufficient.
Adobe Premiere 2017.1
Windows 10 Pro
Samsung SSD 850 EVO system
Samsung SSD 850 EVO Adobe cache
NVIDIA GeForce GTX 970
OWC Thunderbay 12t x 2 in Raid10 configuration (thru Storage Spaces and Disk Management)
