For Sale Canon 19x6,7KAS 1/2" HD Lens for Sony
COW Forums : Classifieds, Personal
Jussi Sjölund
on Dec 15, 2015 at 2:42:09 pm
Canon 19x HD Lens for Sony 1/2"-cameras, for example PMW EX3, PMW 300, PXW 320 och all older XDCAM cameras like PDW F330, F335 , F350.
PRICE: ONLY €800 (EURO) or $880 (USD) Exclusive Shipping and Taxes.
Please contact: info@mountainmedia.se
Perfect as replacement for the original lens that comes with the EX3 with it's poor zoom servo. Here you get a smooth zoom, even in slow speeds!
Good in poor lighting conditions (F 1,6) and no scratches/marks on glass.
Here's a clip filmed with this lens (A TV-series for SVT, the Swedish National Television):
and here you have all the specifications:
IMAGE COMPOSITION KH19x6.7 KAS
Object Image Format 1/2 Inch 16:9 Aspect Ratio
Object Image Size (Presented to
Camera Imagers) 6.97 mm (H) x 3.92 mm (V)
Zoom Ratio 19 X
Focal Length Range 6.7------------127mm
Angular Field of View :
At 6.7mm 55.0 degrees (H) x 32.6 degrees (V)
At 127mm 3.14 degrees (H) x 1.77 degrees (V)
SCENE COMPOSITION KH19x6.7 KAS
Minimum Object Distance (MOD)
(From Front of Lens) 0.9 Meter (50mm with Macro)
Scene Object Dimensions at MOD
At 6.7mm 98.1 cm x 55.2 cm
At 127mm 8.1 cm x 4.6 cm
OPTICAL BRIGHTNESS KH19x6.7 KAS
Maximum Relative Aperture
(F-Number)
At 6.7mm------96.8mm 1 : 1.6
At 127mm (Ramping Characteristic) 1 : 2.1
PHYSICAL ATTRIBUTES KH19x6.7 KAS
Size
Width 112mm 4.4in
Height 88mm 3.5in
Length 171.8mm 6.8in
Weight 2.8lbs 1.27kg
