Denecke TS-2 Time Code Slate with SB sync box
COW Forums : Classifieds, Personal
Frank Nolan
on Nov 5, 2015 at 9:12:54 pm
For sale is a used Denecke TS-2sb time code slate in good working condition. Has been in storage for many years. It has some scratches from normal usage and velcro on the back but works perfectly. $750.00 Call 323-620-5608
The TS-2(SB) reads and
displays SMPTE/EBU Time
code. The SB-2 SyncBox, is
mounted in the battery box.
Eight “AA” batteries are used
to make a compact lightweight
unit. Has the replaceable lexan
face and striped color walnut sticks.
The SB-2 Time Code
Generator jams to all standard
frame rates, including 30 df.
User bits jam automatically
when the time is set. A High
stability crystal is used to
ensure low drift.
Russell Shaver
Re: Denecke TS-2 Time Code Slate with SB sync box
on Apr 8, 2016 at 11:44:03 pm
Did you ever sell your timecode slate?
Frank Nolan
on Apr 9, 2016 at 12:29:29 am
No, it is still available. It can also be upgraded to generate HD frame rates. I called Denecke and they said to send it in and cost was $49.
