Cool Lux Four Light Video Interview Kit - $325
COW Forums : Classifieds, Personal
Patrick Gault
on Sep 7, 2015 at 5:59:18 pm
New Cool Lux Four Light Video Production Kit - great light weight tungsten lighting system for digital video. Very compact and light weight system that is perfect for the lower light requirements of today's digital video cameras. The Cool Lux Mini Cool is a very adaptable light. Just by changing the bulb you can also use the light with 12volt and 30volt power systems. This kit is ideal for producing interviews, documentaries, etc.
Kit includes:
1 Cool Lux Hollywood Light with 500 watt bulb and case - shows signs of use but works great. This light alone sells for $299 new at
Ideal for the pro on the go, the Cool-Lux Combo Light is a fixture born in Hollywood studios, then re-invented with new features for video/studio/location needs. The Combo Light's superluminal but gentle, even diffused light quality makes it perfect for film, video, product or portrait photography. The illuminating qualities of a soft light fixture are based on the principles of a "bounced" light where the lamp never faces the subject directly, unlike a softbox.
A combination of Soft-Light and Broad-Light in one.
Front face of this fixture measures 14 x 9 x 6" -- suitable for a 1-person portrait or small tabletop setup.
More compact than a soft box and mounts in small areas.
Provides shadowless, bright, cool light qualities.
2 Cool Lux Mini Cool - new ($99.95 each at
2 Cool Lux 150 watt bulbs - new
The Cool-Lux Mini Cool features the famous light teamed up with a 150 Watt AC lamp and mounting devices. This package will work with a variety of professional video cameras and with any stand that has a 5/8" stud. Made of aircraft aluminum, this housing is vented and made to cool fast and protect the lamp. It can support a variety of lamps and adapt to many mounting situations with the proper optional equipment. The light stand adapter works with stands that use a 5/8" stud; the 1/4-20 screw can be used in an on camera situation that utilize that specific mount.
1 Cool Lux Micro Cool* - new ($79.95 at
This unit is smaller than the Mini-Cool and works well with smaller cameras; it uses 35 Watt lamps and is made of light weight sheet aluminum. It's lightweight, compact size is very useful for small cameras or any situation where a larger on camera light is not an option. It uses low watt lamps from 20 to 35 Watts; therefore works well with low lux cameras. The MD5000 camera adapter fits nicely into a female camera shoe and also will work with a 1/4-20 mount by using the tightening knob as a separate mounting device.
2 Cool Lux Shoe Mount - new ($15.95 at
2 Cool Lux 12V adapter - new
1 Cool Lux MD-3000 Sound/Light Bar - new ($24.95 at
1 500 watt Dimmer - new ($21.95 at
1 Cool Lux hard side case - new (no longer sold)
3 light stands (new) with bag
* The Cool Lux Micro Cool (on camera light) requires a 12volt battery to operate - not included.
Shipping costs depend on your location. CONUS Only. PayPal Only.
Patrick Gault
Re: Cool Lux Four Light Video Interview Kit - $325
on Sep 11, 2015 at 5:26:39 pm
This kit is no longer available.
© 2018 All Rights Reserved
