Ikegami HL-45 Camera & Sony PVV-3 Betcam Deck, Power supply & Frezzi mini- fill
COW Forums : Classifieds, Personal
Paul Luna
on Oct 22, 2014 at 3:40:42 pm
Used
Seller Notes:
“The HL-45 is a cutting-edge, high-performance digital camera with new-generation ASICs that support reductions in camera size, weight and power consumption. High performance is achieved through three IT CCDs that provide an astounding 900 (HL-45) TV lines, or more, resolution, a modulation depth of 75% (5MHz), a dynamic range of 600%, a sensitivity of f10 (HL-45) at 2000 lux and a S/N of 64dB (NTSC), 61dB (PAL). For cost-savings, the HL-45 connects with existing TA/BS-OCP-40, and newly developed TA/BS/OCP-45 for wideband triax operation. The HL-45 sports a slew of capabilities for leading-edge performance. For example, a memory card can store operating status to facilitate camera setup. The camera uses an advanced RGB DTL System to enhance resolution, plus much more, all made possible through advanced digital signal processing. http://www.ikegami.com/br/products/sdtv/hl45.html Sony PVV-3 Betcam deck, Titan Charger/ Power Supply, Hard Case.”
Paul Luna
