Neumann KMR82i Shotgun Microphone
COW Forums : Classifieds, Personal
Mike Nagel
on Jun 14, 2014 at 11:33:17 am
Hi guys,
selling a Neumann KMR82i Shotgun Microphone, one of the best shotgun mics. The mic has just been evaluated by Sennheiser (which bought Neumann years ago) and the mic is in mint condition and performs beautifully. Comes with leather pouch.
Specifications:
Transducer Pressure Gradient Condenser
Polar Pattern Supercardioid/Lobe
Frequency Response 20 Hz - 20 kHz
Dynamic Range (Typical) 116 dB
Signal-to-Noise Ratio CCIR 468-3= 71 dB
DIN/IEC 651= 82 dB
Maximum Input Sound Level Not Specified by Manufacturer
Power Requirements Phantom Power (48v +/-4v)
Output Impedance 150 Ohms
Output Connectors 3-Pin XLRM Type
Pad None
Low Frequency Roll-Off Between 2 kHz and 15 kHz the KMR 82 has a boost to compensate for HF transmission losses in air when recording distant sound sources.
This may overemphasize any sibilance if the microphone is used close-up. Therefore, a two-position slide switch allows to select the setting that is best for balanced upper frequencies.
The KMR 82 has a high-pass filter to suppress subsonic interference. The cutoff frequency may be raised to 120 Hz ( - 3 dB) with a built-in two-position slide switch.
Dimensions 15.5512 x .82" (395 x 21mm)
Weight 7.5 oz. (250 g)
price: US$900.00 + shipping. Item is located in Los Angeles and can be picked up locally.
- Mike
Profiling & Calibration Workflow Tools: http://www.DisplayCalibrationTools.com
Mike Nagel
Re: Neumann KMR82i Shotgun Microphone
on Jun 20, 2014 at 3:54:05 am
SOLD
