Panasonic Lumix GH-3 Body
COW Forums : Classifieds, Personal
Ray Tragesser
on Apr 21, 2014 at 8:02:08 pm
For Sale - $850 + Shipping
Panasonic Lumix GH3 - Body Only - Single Owner - Personal Camera
Lightly used. Perfect condition. No signs of wear or tear. Comes with original box, manuals, CD's, strap, charger, and battery. You won't find a better used version than this one. Absolutely perfect.
Product Information
Panasonic Lumix DMC-GH3 Micro 4/3 Digital Camera True-to-life detail through excellent resolution. The Panasonic Lumix DMC-GH3 has been engineered to incorporate a 16.05-megapixel Digital Live MOS Sensor a 4-CPU Venus Engine and a newly designed low-pass filter. The creative expression made possible by these innovations which render even the finest textures in intricate detail breaking new ground in photographic realism. This model also features Contrast AF with a high level of response. And its magnesium alloy frame is tightly sealed to resist splashes and dust making the DMC-GH3 rugged enough to withstand the rigors of professional use. Advances have been made in video performance as well. In addition to supporting a wide range of recording formats the DMC-GH3 features a special heat-dispersing design for extended high-quality recording. Its specifications match those of many professional cameras ensuring that it meets the demands of video field work. Key Features: 16.05-megapixel Digital Live MOS Sensor The DMC-GH3 features a 16.05-megapixel Digital Live MOS Sensor with a level of sensitivity that produces flowing gradation from shadows to highlights. High resolution and a wide dynamic range create truly stunning images that look like you could reach out and touch them. High-sensitivity ISO 12800 (extended: ISO 25600) and extensive noise reduction give you remarkable images even in dim lighting. Venus Engine The Venus Engine has an unprecedented ability to process both still and video signals with razor-sharp clarity. 3D Noise Reduction (3DNR) and Multiprocess Noise Reduction (MNR) work together to attain superb noise-reducing performance. Four CPUs process these signals instantly to render images with excellent definition and lifelike ambience. Low-Pass Filter New technology has also been applied to the low-pass filter on the surface of the Digital Live MOS Sensor.
Product Identifiers
Brand Panasonic
Model DMC-GH3
UPC 5025232701612, 885170103887
Key Features
Camera Type Mirrorless Interchangeable Lens
Digital Zoom 4x
Sensor Resolution 16.0 MP
Screen Size 3"
Lens System
Lens For SD Body Only
Light Sensitivity Max 1600
Camera Flash
Flash Type Built-In
Memory / Storage
Supported Flash Memory SD Memory Card, SDHC Memory Card, SDXC Memory Card
Depth 3.23 in.
Height 3.68 in.
Width 5.23 in.
Weight 19.4 Oz.
Display Type OLED
Display Size 3"
File Format
Digital Video Format AVCHD, MOV, MPEG-4
Still Image Format JPEG, MPO, Raw Image
Max Video Resolution 1920 x 1080
Other Features
Additional Features HDMI, Interchangeable Lenses
Dan Gunn
Re: Panasonic Lumix GH-3 Body
on Apr 21, 2014 at 8:46:34 pm
I got interested in this camera when I saw what you achieved with it!
Can I talk you into a trade....I have too much equipment and not enough
© 2018 All Rights Reserved
