For Sale - AJA KLBox
COW Forums : Classifieds, Personal
Phil Yunker
on Sep 2, 2013 at 9:41:03 pm
Condition - like new
Price - $250.00 - or best offer
*****AJA KLBox ONLY NO CABLES*****
Contact - philyunker at mac dot com
Description:
AJA's KL Box Breakout Box for Kona-LH, Kona-LHe and Kona-LSe offers functionality and versatility you will find in a breakout box such as this. This box can be easily rack-mounted or placed on top of a broadcast monitor or editing desk for versatility.
The KL Box Breakout Box for Kona-LH, Kona-LHe and Kona-LSe connects the analog and digital worlds by offering I/O for both up conversion and Dual Link. This box provides optimum quality for SD and HD, which is the maximum allowed in SMPTE SDI standards.
The KL Box Breakout Box for Kona-LH, Kona-LHe and Kona-LSe also includes hardware sample-rate conversion on AES inputs eliminating source-synchronizing requirements. As the only card available supporting HD/SD analog I/O, KL Box Breakout Box for Kona-LH, Kona-LHe and Kona-LSe is perfect for not only uncompressed, but also HDV and other diverse workflows.
Rack-mountable
Optimum Quality
This box provides optimum quality for SD and HD which is the maximum allowed in SMPTE SDI standards.
Capturing
Using the QuickTime format, this box helps when capturing directly to 10-bit files on disk, and also supports many legacy 8-bit formats for backward compatibility. This box also supports DVCPROHD and HDV, DV25, DV50, JPEG, and much more.
Audio Support
This unit offers all the audio support you would ever want including native OSX multi-channel audio and 24-bit AES/EBU digital audio at 48 kHz for digital production.
Hardware Sample Rate
This Breakout Box for Kona-LH, Kona-LHe and Kona-LSe also includes hardware sample-rate conversion on AES inputs eliminating source-synchronizing requirements.
Diverse Workflow
As the only card available supporting HD/SD analog I/O, this Breakout Box for Kona-LH, Kona-LHe and Kona-LSe is perfect for not only uncompressed, but also HDV and other diverse workflows.
