For Sale - AJA KBox
COW Forums : Classifieds, Personal
Phil Yunker
For Sale - AJA KBox
on Sep 2, 2013 at 9:36:04 pm
For Sale - AJA KBOX
Condition - Like New
*****KBOX ONLY NO CABLES*****
Price - $125.00 - or best offer
contact - philyunker at mac dot com
Description - AJA's K-box Breakout Box for Kona 2 will help simplify your interfacing issues by offering a 19-inch, rack-mountable breakout box that attaches to the KONA 2 with just two cables. This box offers all the same inputs and outputs as the standard breakout cable, and can be easily rack-mounted or placed on top of a broadcast monitor or editing desk.
This box offers XLR and BNC AES output, 2-channel RCA analog audio monitoring, and looping BNC Genlock reference connectors. You can independently switch between HD and SD with the K-box since there are two HD/SD SDI video outputs and a component analog output. With this feature SD analog can be configured as composite.
The K-box also supports Dual Link 4:4:4 HD-SDI, an emerging technology on the Macintosh platform. This feature is also known as Sony HDCAM SR or Thompson Viper Format. The KONA 2 Dual Link supports full bandwidth 4:4:4 RGB at 10-bits (12-bit capable) for 1080i, 1080p, and 720p formats.
It also supports Dual Link 4:4:4 HD-SDI, an emerging technology on the Macintosh platform. This feature is also known as Sony HDCAM SR or Thompson Viper Format. The KONA 2 Dual Link supports full bandwidth 4:4:4 RGB at 10-bits (12-bit capable) for 1080i, 1080p, and 720p formats.
Audio Conversion
You can eliminate the need for audio source synchronization with the high quality input sample rate conversion on AES inputs.
Broadcast Quality
This box features full 10-bit, broadcast quality, motion-adaptive HD to SD down-conversion, SD to HD up-conversion, and automatic HD/SD 12-bit component analog output.
Switch Between HD and SD
Rackmountable
This box can be easily rack-mounted or placed on top of a broadcast monitor or editing desk for versatility.
