For Sale: Bebob FOXI Focus Iris Control Panasonic AG-HPX, AF101, AG-DVX100/A/B, AG-HVX200
COW Forums : Classifieds, Personal
Marion Laney
on Jun 30, 2013 at 7:52:09 pm
EBAY listing:
Bebob Foxi-DVX-HD
Follow Focus & Iris Remote Controller
for Panasonic AG-DVX / AG-HVX / AG-HPX / AF101 Camcorders
This Bebob Foxi-DVX-HD is in good condition (see photographs) and in perfect working order but with some wear on the graphics. New price around $390.00.
Foxi by Bebob Engineering is a professional remote device for controlling the Focus and Iris functions of any Panasonic camcorder with a Lanc port.
The following functions can be controlled:
• Focus (rotating knob)
• Switching between Auto-Focus and Manual-Focus
• Iris (slider paddle)
• Switching between Auto-Iris and Manual-Iris
The Focus knob is designed in similar style to a Follow-Focus knob with a diameter of 60mm with an approximate 270 degrees of rotational travel. A built in non-adjustable fluid friction allows slow, accurate and repeatable Focus control movements.
The control of the iris is made using a throttle design sliding paddle indicator.
Two sliding switches located at the bottom of the BeBob Foxi housing allows remote switching from Auto to Manual Focus and from Auto to Manual Iris and vice versa.
Foxi by German company BeBob is a professional Focus and Iris Lanc controller - you can attach to the pan bar of your tripod or use on 15mm rods for hand held work. As a follow focus it gives you hard stops for repeatable focus pulls for camera that have focus rings which just rotate without stopping.
Both focus and Iris offers markable scales. (NOTE: Do not use permanent markers.)
The Foxi can be mounted to a tripod pan arm for studio configuration or on 15mm light weight matte box rods for cinema configuration (using the supplied spacer bracket).
It is designed for use only with Panasonic DVX100B and HVX200 cameras but will work with any other Panasonic cameras that have a LANC port including the AF101.
• Focus / Iris remote for Panasonic camcorder.
• Compatible with any Panasonic camcorder with a Lanc port.
• Built-in friction.
• Repeatable positions.
• Auto / manual Switches.
• Quick-clamp for Pan-Arms or rods up to 34mm diameter.
• Coiled cable with elbow plug.
Marion Laney
Atlanta & Gulf Coast Producing in HD-4k-35mm
Food Network "Good Eats" Peabody Award
Bridgestone Golf, Tennis pro's (live action & for VFX)James Beard Foundation- National Awards Committee
Experienced producing/shooting on 3 continents & many islands
"From Tabletops to City Blocks!"
© 2018 All Rights Reserved
