Matrox MX02 Capture, Playback and MP4 H.264 Hardware Acceleration Desktop Unit
COW Forums : Classifieds, Personal
Andrew Lock
on Jan 10, 2013 at 8:08:48 am
This is a desktop unit that allows you to capture video from any format, play it back on an HDMI monitor, and speed up the creation of MP4 files (H.264) via the accelerator hardware included.
Works with Mac or PC desktop computers.
The unit cost $1950.00, it's barely used, and your price is just $500. No offers, cash only please.
Here's some more details about it:
The MXO2 Max for Desktop from Matrox is a device that combines the functionality of an HDMI & analog I/O card in the form factor of a miniature breakout box. It will capture, convert, and play multiple video formats. This model features adapters (PCIe and ExpressCard/34) designed for use with desktop PC or Intel-based MacBook Pros, Mac Pros, and Apple Xserve systems. This model additionally features Matrox MAX technology for faster than real-time H.264 encoding.
This device's small footprint makes it easy to transport. It is compatible with most industry-standard applications, such as Final Cut Pro, Adobe Premiere Pro, and Photoshop, among others. Moreover, its color-calibration tool can be used to turn your HDMI monitor into a professional-grade video monitor.
Note! Adobe Premiere Pro CS5 support for Mac OSX to be available in early November 2010.
This model is designed for use with PC or Mac desktop systems This model features Matrox MAX technology for faster than real-time H.264 encoding. It features a small footprint and is easy to connect to cameras and monitors Capture and play back high-definition video in multiple formats Turn your HDMI screen into a professional-grade video monitor with color-calibration tools, including blue-only Genlock SD analog black burst (bi-level) or HD tri-level sync are available A 10-bit hardware, scaling engine allows for real-time up-scaling, down-scaling, and cross-conversion on capture and playback Up to (5) user-selectable simultaneous video outputs for HD and/or SD on HDMI, SDI, and analog are available This unit supports 5.1 surround-sound monitoring on the HDMI output It supports RS-422 machine control for frame-accurate capture and print-to-tape Capture to a variety of Adobe Premiere Pro and Final Cut Pro codecs, including Apple ProRes 422 HQ and 10-bit uncompressed HD File-based workflow support is available for XDCAM, XDCAM HD, XDCAM EX, P2, and P2HD This solution supports RED workflow HD-SDI closed-captioning support is a standard feature It is compatible with your applications such Final Cut Pro, Adobe Premiere Pro, and Adobe Photoshop, among others
