BroadcastPix Fly Pack Switcher For Sale Slate Granite 5000 HD 16 inputs
COW Forums : Classifieds, Personal
Vincent Reynaud
on Dec 16, 2012 at 5:33:21 am
Great Broadcast Pix Slate 5000 model Slate 5016G HD Rarely used, great shape, 1 wheel on the travel case needs TLC, otherwise perfect.
Was the show demo unit from the manufacturer, so it has all the bells and whistles and expensive options Was $78,000 + tx:.
Make me a reasonable offer I WILL TAKE IT . vreynaud(at)
read info here:
Installation guide & Specs: Download PDF here (29MB)
HD/SD 2ME switcher, plus control panel and 16x16 HD/SD SDI router  Switcher
- Inputs Up to 16 live inputs + 2 clip stores + 5 graphics stores
- Keyers and DVEs Up to 6 Keyers with a DVE on each keyer, 2 inputs can be external key & fill, 1 Chromakey Lumakey
- SDI Live input formats Up to 16 HD/SD SDI with genlock or asynchronous
- Outputs 8 HD/SD SDI (program, preview, 6 auxiliary), plus 1 analog
- Break-out cables 1 YUV/composite, 1 analog audio
- Multi-View Full motion monitoring on the VGA monitor of preview, program, 7 live sources
and 2 clips and slower monitoring of other sources
- HD Character Generator Inscriber TitleMotion Character Generator, with rolls, crawls and animations
- HD Clip Store Dual channel, with up to 500GB of storage, with key and audio.
- QuickTime and uncompressed
- HD Graphics Stores 5 channels of graphics for CG, stills and/or logos, with up to 160GB of storage
- Fluent Software Fluent Workflow Software: includes Fluent Watch-Folders & Fluent Macros
- AutoAspect Mix 4:3 and 16:9 sources, clips and graphics without stretching pictures
- DualAspect Simultaneously output 16:9 and 4:3 program outputs
- Fail-safe on-air All live inputs can still switch even if the computer stops
- Redundant power for the panel, router and workstation
- Hardware 2ME control panel, G-Series rack-mountable Premium Workstation with Slate video boards,
- HD router and back-up system drive
© 2018 All Rights Reserved
