What Happens to AE Render Engine...?
COW Forums : Adobe Creative Cloud Debate
Andrew Saliga
on May 9, 2013 at 3:14:14 pm
We have a render farm that we send Maya and C4D renders to, and were planning on building out the system to handle AE renders. Previously, the render engine was an app that came along with After Effects, but did not require a license for each instance you'd run. Now that AE installs are tied to a Creative Cloud account, how does one go about installing multiple copies?
Andrew Saliga
I/O Specialist/Assistant Editor
Steelehouse Productions
http://www.steelehouse.com
Roland R. Kahlenberg
Re: What Happens to AE Render Engine...?
on May 9, 2013 at 6:55:27 pm
I believe that AE's Render Engine, with AE CC, will work in the same manner as it did previously.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE
Kevin Monahan
on May 9, 2013 at 7:43:41 pm
[Roland R. Kahlenberg] "I believe that AE's Render Engine, with AE CC, will work in the same manner as it did previously."
Correct Roland.
Nothing has changed between AE CS6 and AE CC in regards to setting up AE render engine-only nodes.
Instructions here still apply here:
http://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c11...
Kevin
Kevin Monahan
Social Support Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter!
