new resolve 12
COW Forums : Adobe Creative Cloud Debate
Ricardo Marty
new resolve 12
on Apr 14, 2015 at 1:44:19 am
Redesigned User Interface
• New modern, flexible and scalable user interface
• UI designed to scale from 15” Macbook Pro to 5K Retina iMac
• Support for high DPI monitors on Windows
• Multiple user support is now optional
• Postgres server is now not installed by default
Media Page
• Greater layout flexibility
• New simple clip relink
• Drag & drop clips from Mac OSX Finder or Windows Explorer to media pool or timeline
• Media Storage Favorites allow folder bookmarks
• Media Storage sub-clip generation
• Media management controls to Copy, Move and Transcode
• Project Archive and Restore
• Media Pool Smart Bins
• Customizable metadata based display name for clips
• Optimized media and proxy support
• Automatic Dual sound system sync based on waveform
• Optimized Media Thumbnail scrubbing
• Media Storage option to list Individual frames as separate items
Edit Page
• Multi-cam editing
• Guaranteed real-time audio playback for all playback speeds
• Automatic audio pitch correction for slow or fast playback speeds (Mac)
• Support for speed changing audio clips with pitch correction
• Audio playback using JKL dynamic trim
• VST and AU Audio Plugin Support (Mac & Windows)
• Clip and Track automation control for audio
• Offline reference video wipe playback on the SDI output in Edit and Color page
• Curve editor for transitions
• Low latency JKL playback control and slow-mo playback
• Slow-mo playback using JKL keys
• Expanded multi-selection trimming
• Better trim behavior when sliding multiple selected clips in the same track
• Timeline clip match frame to the media pool source clip
• Split Clip Roll edit
• Split edit trim maintains linked and preceding audio sync
• Nest timelines into any other timeline
• Motion Path editing with bezier handles
• Simplified Track selection for copy/paste operations
• Zoom to fit Timeline is now a toggle operation
• Media clips and timelines consolidated in the Media Pool
• Flip/flop in edit sizing
• Automatic Slip and Move operations for clips out of sync
Color Page
• DaVinci Resolve Color Management (RCM)
• New Custom Curves with bezier handles
• New Perspective 3D Tracker
• New 3D Keyer
• Despill option to automatically reduce chroma key spill
• New Matte Finesse Controls
• Compound Nodes to create complex looks using nested node graphs
• Node Graph clean-up tool
• Key processing by routing Key to RGB and RGB to Key in the node graph
• Window conversion to Power Curve Window
• Flatten Pre and Post group grades into Clip grade
• Auto shot match between two or more clips
• Add correction with keyframes in timeline thumbnail context menu
• Ability to ripple grade from any node to selected clips or current group
• Ability to append current node to selected clips in timeline
• Delete 'Unused Versions' option
• Ability to view and change ISO for Blackmagic Camera RAW clips
• Black Sun Highlight Correction for Blackmagic Camera clips
• Timeline Smart Filters
• Pitch/Yaw in edit, input, node and output sizing
• Lightbox on second screen
• Docked scopes and Clip/System Info
Deliver Page
• Export to ProTools
• Render audio only
• Remote Rendering
• Progressive disclosure of advance render settings
General
• Modern 64-bit QuickTime support on Mac OS X
• QuickTime support for DNxHR codec
• Missing clips on storage show up as offline media
• Additional keyboard shortcuts
• ARRI Alexa 65 support
• ALEXA Open Gate and Canon RMF clip resolution improvements
• Spanned Canon C300 clip support
• Canon still camera RAW format CR2
• Native M4V file support
• Sony XAVC Intra encoding (Full version only)
• Panasonic V35 IDT included for ACES workflows
• Quad 3G SDI support on DeckLink 4K Extreme 12G
• Level A SDI support with Blackmagic I/O hardware
• OpenEXR v2.2.0 read/write with DWAA/DWAB compression
• ACES v1.0 support
• Support for 32, 44.1, 48, 88.2, 96, 192 kHz audio
• General performance and stability improvements
David Mathis
Re: new resolve 12
on Apr 14, 2015 at 3:56:16 pm
There are a couple of threads over in the FCP X Or Not forum on this. Having said that, audio playback issues need to be addressed along with video playback as well in the edit page before Resolve could be considered for use as an editor.
I am very impressed by the progress Resolve is making. Looks good on paper but needs some real world testing.
The trim tools look solid and the media pool has some nice features being added in. I am very interested in this version and ready to give it a try once it is made available. Also excited about the news of Fusion.
Ricardo Marty
Re: new resolve 12
on Apr 14, 2015 at 9:22:12 pm
i think that it dosent make sense to put out version 12 and not have corrected those issues, but who knows?
ricardo marty
David Mathis
Re: new resolve 12
on Apr 14, 2015 at 9:39:35 pm
Perhaps those issues have been resolved, pardon the pun. Still looking forward to the new version. Might wait for an update or two before diving in.
Andrew Kimery
Re: new resolve 12
on Apr 15, 2015 at 11:39:19 pm
[David Mathis] "There are a couple of threads over in the FCP X Or Not forum on this. Having said that, audio playback issues need to be addressed along with video playback as well in the edit page before Resolve could be considered for use as an editor. "
The BM people I talked to at NAB said that there is an all new playback engine so audio and video playback should be significantly improved. We have to wait until July to see if that's true or not.
David Mathis
Re: new resolve 12
on Apr 15, 2015 at 11:44:00 pm
I hope this mean raw files will playback just as well. So far ProRes seems to be o.k. until audio gets thrown in the mix. They forgot to add 3D title, oops! ;-)
