Update Apps without removing previous versions CC 2017?
COW Forums : Adobe Creative Cloud
Walter Stabb
on Sep 15, 2017 at 2:52:01 pm
Hi all,
Quick question. Previously when updating apps there was the possibility, through the advanced menu of the update window, to untick the default remove previous versions. Is a similar function available in the current version of CC (which doesn't seem to feature an Update window)?
I am aware of the process to install previous versions, which clearly provides a work around but would rather just install new versions parallel to the previous.
Andy Edwards
Re: Update Apps without removing previous versions CC 2017?
on Sep 26, 2017 at 8:07:12 pm
When it's a major release like 2015 to 2017 vs. a dot update / patch you get the opportunity to keep the previous version. The installer will not let you install 2017.x and keep it at that version when you upgrade / patch to 2017.x.x.
File a feature request with Adobe to see if they will incorporate this request into their CC installers.
Andy Edwards
Walter Stabb
on Oct 2, 2017 at 2:06:38 pm
Thanks for that clear response Andy, much appreciated!
