I am stupid. 10GbE copper uses Cat 5e
COW Forums : NAS - Network Attached Storage
John Davidson
on Jun 12, 2013 at 7:22:53 pm
So I just realized that the process to get us to 10Gbe is a lot less complicated than I thought.
Am I right on this? If we already have fast storage feeding 1GbE using a Small-Tree switch, we can theoretically replace that with this netgear switch:
http://www.netgear.com/business/products/switches/prosafe-plus-switches/XS7...
Get some converters to turn the GBe into thunderbolt for our iMacs, and we're off to the races? Something like this:
http://www.small-tree.com/ThunderNET_TN1_2P_p/tn1-2p.htm
That seems too easy. Obviously the speed of our server will be the deciding factor if this works, but we're getting about 1800Mb/s from it, so I think we should be good there for 3 or 4 suites tops.
Bob Zelin
Re: I am stupid. 10GbE copper uses Cat 5e
on Jun 13, 2013 at 2:02:06 am
you will find that unless you are running 25' or under, you will get in trouble with hi bandwidth signals running at 300MB/sec. If you are going to proceed with the 10g switch, do yourself a favor, and spend a couple of bucks more and get some Cat6 cables. Good up to 55 meters.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
maxavid@cfl.rr.com
