Export Codec Options
COW Forums : Telestream ScreenFlow
Jim Cunningham
on Dec 26, 2012 at 2:19:43 pm
Starting to play w/ Screenflow 4. (MBP Lion) I went to export & there were various Web codecs, including wmv (interesting). In addition, there was a lossless category (animation) and a ProRes 4444 w/alpha. I was trying to copy/edit/create a ProRes (LT) etc. but the ProRes copy button is grayed out. I do have FCP & CS6 on this MBP and so have all of the ProRes codec (and many other), but can't seem to access them.
Any insights would be appreciated.
Cheers,
Jim Cunningham
Re: Export Codec Options
on Dec 26, 2012 at 3:02:09 pm
To follow up; I tried to copy/edit/modify the lossless codec, but when I select the video to modify, it just brings me back to the previous codec listing page.
Craig Seeman
on Jan 31, 2013 at 2:34:30 pm
I apologize for not seeing this before.
After clicking on Manage, you should be able to Copy the Lossless template and then click on the Edit button. That brings up the QuickTime Movie Settings window and then you'd click on Settings and select from all the Quicktime codecs in your system. It's not clear to me that's what you're doing.
Are you on OS 10.8.2, 10.7.5, 10.6.8?
